Watchapp: Muninn - Battery Wisdom by Chris Lewis
:party: Chris Lewis just released version 1.17 of Muninn - Battery Wisdom!
  • Bring back the bird on Aplite
  • Add information page
  • Re-organize the app menu
  • Handle <10% increase as not a charge event
  • More Aplite memory optimizations
:party: Chris Lewis just released version 1.18 of Muninn - Battery Wisdom!
  • Respect Quiet Time for notification/alert vibrations
  • Fancy animation for loading graph data points
:party: Chris Lewis just released version 1.19 of Muninn - Battery Wisdom!
  • Add option setting for ‘one day remaining’ alert
  • Move settings to separate menu
  • Disable animations on Aplite to save more memory for new features
  • Update to pebble-scalable v2
:party: Chris Lewis just released version 1.20 of Muninn - Battery Wisdom!
  • Update navigation from main screen to graph, drill down to log
  • More consistent screen designs
  • Condensed menus
  • Improve graph screen look and behavior
  • Select graph datapoints to jump to that log entry
  • Lay groundwork for phone-side data sync (no feature yet!)
:party: Chris Lewis just released version 1.21 of Muninn - Battery Wisdom!
  • Sync up to 120 days of data to the JS side
  • See four initial stats based on extended history (all-time avg, last week avg, charge events, mean time between charges)
  • Fixes for crash rendering graph in specific scenarios
  • Complete conversion of JS code to TS with jccit/PebbleKit.ts
  • Graph plots points based on time, not index, showing any gaps in sample history
:party: Chris Lewis just released version 1.22 of Muninn - Battery Wisdom!
  • Add support for Pebble Time Round (chalk)
  • Remove large status text and replace with decorated day/night skyline
  • Fix for graph drawing predictions out of bounds for charging samples
  • Potential fix for launcher icon on Aplite
:party: Chris Lewis just released version 1.23 of Muninn - Battery Wisdom!
  • Fix text alignment in main window
:party: Chris Lewis just released version 1.24 of Muninn - Battery Wisdom!
  • Draw skyline decoration on message window as well as main window
  • Show one decimal point for the days remaining estimate if in single digits
  • Fix for counting consecutive charge events when calculating mean time between charges
:party: Chris Lewis just released version 1.25 of Muninn - Battery Wisdom!
  • Fix for app crash during sync when the only charging interval is too short
:party: Chris Lewis just released version 1.26 of Muninn - Battery Wisdom!
  • Initial version of web platform for visualizing the full 4 months of data stored on the phone with extra stats and interactive chart. Access via the app settings in the Pebble app!
  • If launched with no ‘last charge time’ but over 90% battery, assume that is the first charge time to get value sooner
  • Re-organize menus
:party: Chris Lewis just released version 1.27 of Muninn - Battery Wisdom!
  • Add setting to automatically update the web config view data daily at mid-day
  • Add export graph PNG and graph data CSV buttons to the config web page
  • Lay groundwork for the ‘population insights’ feature (WIP)
:party: Chris Lewis just released version 1.28 of Muninn - Battery Wisdom!
  • Refine average drain rate calculation on JS side to use sum of drops instead of averaging rate estimations. Should slightly reduce underestimation.
:party: Chris Lewis just released version 1.29 of Muninn - Battery Wisdom!
  • Use fixed-point arithmetic to allow much more precision on estimated discharge rate, and more accurate ‘days remaining’ estimate. No more huge swings for single digit changes!
  • Attempt to update web history as part of opening settings in the Pebble app for up to date history data.
  • Web platform improvements: clearer comparison stats, increase provisioned throughput, fix display of relative difference stats.
:party: Chris Lewis just released version 1.30 of Muninn - Battery Wisdom!
  • On the watch, note a gap of >12h in samples but don’t create a new one. The next sample should then be a regular one. Should help with big gaps in samples.
  • On the phone side, don’t include samples immediately after a large gap in samples in the average battery life calculation. Should help make the global stats a lot more accurate.
:party: Chris Lewis just released version 1.31 of Muninn - Battery Wisdom!
  • Fix menu window header text
:party: Chris Lewis just released version 1.32 of Muninn - Battery Wisdom!
  • Fix next charge date colliding with actionbar issue
  • Fix some icon positions on Chalk
:party: Chris Lewis just released version 1.33 of Muninn - Battery Wisdom!
  • Cleaner main screen UI: removed status string, more consistent icon and text alignment
  • Add labels for previous and next charge dates
  • Free enough memory to bring back original braid and top two icons on OG Pebbles
  • Add date format setting
:party: Chris Lewis just released version 1.34 of Muninn - Battery Wisdom!
  • Fix issue drawing graph with large gaps in data
  • Fix issue showing 100% battery cleanly on smaller displays
:party: Chris Lewis just released version 1.35.0 of Muninn - Battery Wisdom!
  • Fix initial empty data display on Aplite
:party: Chris Lewis just released version 1.36.0 of Muninn - Battery Wisdom!
  • Remove ‘num charges’ watch-side sync stat (not very useful)
  • Add ‘estimated battery life’ watch-side sync stat (very useful!)
  • Improve design and clarity of sync stats screen
  • Standardize min. samples for sync stats and web (8 or 2 days)
  • Daily upload enabled by default for new users to try and improve global stats data quality and get them value sooner
  • Substantial non-graphical groundwork laid for PR2 support
