Chris Lewis just released version 1.5 of Muninn - Battery Wisdom !
Retry wakeups if they collide with other apps
Update iconography
Handle >99% measures in main window and log window
Further clarify initial stages of sampling on main window
It’s true! Muninn is here to help report battery life using an ultra-low battery impact approach. So far I’ve had excellent bug reports and feedback, but more is better! Please try it out and post any good/bad observations here.
Source code is also readily available: pebble-dev/watchapps/muninn at master · C-D-Lewis/pebble-dev · GitHub
joshua
December 5, 2025, 9:28pm
3
We’ve transferred the topic to you, so I think you should be able to edit the OP now, if you like!
Thanks! I’m continuing where the automation left off
Chris Lewis just released version 1.6 of Muninn - Battery Wisdom !
Fix next sample text position
Add initial timeline pin for noon of day charge may run out
ishotjr
December 11, 2025, 5:44pm
6
I’m absolutely loving this app! great work, @chrislewis !!!
Thanks! Some way to go on accuracy and Emery but I’m working on it!
Chris Lewis just released version 1.7 of Muninn - Battery Wisdom !
Major UI overhaul to scale up properly for Emery
Re-designed the data log to be more obvious
Implement scrolling on message windows
Fix issue when a ‘no change’ log entry time range can overlap a subsequent discharge log entry time range
Use absolute time to schedule the next wakeup instead of counting seconds
Show precise time of next wakeup
If woken up prematurely, silently reschedule
Rhialto
December 16, 2025, 12:49pm
9
I guess you’ll make it work with the 1% increment Emery can provide?
Chris Lewis just released version 1.8 of Muninn - Battery Wisdom !
Fix animation bug when no data has been gathered yet
It will use whatever the platform provides - indeed for PT2 and P2D this is 1% increments
Rhialto
December 16, 2025, 10:27pm
12
Like me you can’t test this in current emu, so I guess you tested on hardware? I hope they will add it soon to the emu.
Chris Lewis just released version 1.9 of Muninn - Battery Wisdom !
Fix bug calculating days remaining from the data log, not the live battery level
Move data log to the Down button on the main screen
Better sleeping bird image
Yes, my PT2 test unit reports 1% increments
Chris Lewis just released version 1.10 of Muninn - Battery Wisdom !
Fix bug counting an ‘on charger’ entry as ‘charged up’ regardless of charge difference
Layout improvements
Chris Lewis just released version 1.11 of Muninn - Battery Wisdom !
Update algorithm to correctly include ‘no change’ time intervals in overall estimation calculations, improving accuracy on older watches (thanks jojomuc!)
Update data log to show time intervals more intuitively
Add new ‘high drain alert’ option for if a new estimate suddenly becomes 2x the current historical average.
Chris Lewis just released version 1.12 of Muninn - Battery Wisdom !
Show time since last observed charge (increase)
Show predicted date of next charge
Show alert when there is about one day remaining
Allow a mix of ‘no change’ and discharge samples in initial two samples
Increase the log length from 8 to 16
Show log usage in the log window header
Add days remaining/rate estimations to each individual log entry for a future feature that tracks app accuracy
Note: data will be reset for this update to allow new features, and to prevent a reset being required in the foreseeable future. Sorry!
Chris Lewis just released version 1.14 of Muninn - Battery Wisdom !
Fix out of memory crash on Aplite by removing/re-using some images
Test with only one required full sample, instead of two.
Chris Lewis just released version 1.15 of Muninn - Battery Wisdom !
Revert minimum samples to two: watches reporting 10% increments pretty much require this
Chris Lewis just released version 1.16 of Muninn - Battery Wisdom !
Add initial graph and trend accuracy features
