Watchface: TopoLocal by Techconnect
:party: There’s a new watchface on the Rebble App Store!
:party: Techconnect just released version 0.3.1 of TopoLocal!
  • Four layouts and four fonts, with ten palettes and custom colors.
  • Close-fitting panels, halos or hollow digits. Compact and Atlas can choose a quiet corner.
  • Three contour styles: Uniform, Color contrast and Bold lines. Bold thickens every fifth elevation contour in your chosen line color.
  • Atlas now shows a distance bar and the height between contours.
  • Optional shake to switch date and temperature; phone settings add a map preview and refresh after saving.
  • Shorter settings text. Your preferences and last map carry over from 0.2.2.
:party: Techconnect just released version 0.3.2 of TopoLocal!
Added LECO as a fifth clock font, using the font built into Pebble. Available in Compact, Halo, Atlas and Stack, with panel, halo or hollow digits. The phone preview uses a substitute font.
:party: Techconnect just released version 0.4.0 of TopoLocal!
Added optional experimental compass rotation. Select Shake action > Compass, then shake your wrist: the map turns with your heading for 12 seconds after calibration while the clock stays fixed. Compass is off by default; existing preferences stay unchanged.
The map includes surrounding terrain so its edges stay filled during rotation. Magnetic correction uses WMM2025 offline on the phone.
Please allow a fresh map download after updating. Larger maps may need the phone to resend them after restarting the watchface. Physical compass accuracy and battery use are still unverified.
:party: Techconnect just released version 0.4.1 of TopoLocal!
Fixed disappearing terrain after restarting the watchface or losing the phone connection.
The watch saves a full map when it fits, otherwise a cropped copy with reduced detail if needed. A cropped copy stays north-up until the phone restores the full map. Cached terrain can return before a new location fix, and failed transfers can retry.
Failed updates or updates with no visible contours keep the previous map and its original age. This also fixes a flatness check that could discard valid contours.
Your settings stay unchanged. Allow one successful map transfer after updating to save the new offline copy. Compass remains experimental.
:party: Techconnect just released version 0.5.0 of TopoLocal!
Added Pebble 2 Duo support in the same TopoLocal package.
Duo gets Dark and Light themes, all four layouts and five fonts, with sizes and spacing suited to its 144×168 display. Use uniform contours or bold main lines. Date, temperature, AM/PM, Atlas scales and offline maps work on both watches.
Reduced memory use and kept the missing-map fixes from 0.4.1. Maps and appearance settings are stored separately for each watch model, so switching watches keeps the correct screen size and colors.
Duo keeps its map north-up. Compass rotation remains an optional experimental feature on Time 2; it did not pass our Duo emulator tests and is not offered there.
Time 2 keeps its existing colors and preferences. Keep your phone connected until the first map loads on Duo.
:party: Techconnect just released version 0.5.1 of TopoLocal!
Reduced stack memory use on Pebble 2 Duo during startup and drawing. This addresses a risk found while investigating a reported crash; confirmation on the affected watch is still needed. No changes to appearance or settings.
:party: Techconnect just released version 0.5.2 of TopoLocal!
Choose Date, Temperature or Steps in Time → Show. Steps use today’s total from your watch and stay on the watch.
With Steps selected, the Switch information shake action flips between steps and temperature. If weather is unavailable, it returns to steps.
Works with the existing layouts and fonts on Pebble Time 2 and Pebble 2 Duo. Keeps the Duo stability fixes from 0.5.1.
