Tangent by astosia
astosia just released version 1.7.0 of Tangent!
Fixed misaligned hour digits when quickview is on and date is off.
Added options to change the colour of the sub-dial, and to keep the sub-dial visible when seconds hand times out
astosia just released version 1.8.0 of Tangent!
Adds Roman Numerals as an option - thank you FearlessOtter for the suggestion
astosia just released version 2.0.0 of Tangent!
Adds 2nd Timezone to sub-dial options. Adds option for smooth(er) sweep for the second hand (updates 5 times per second, not on Aplite). Tidied up the settings page to make options clearer
astosia just released version 2.1.0 of Tangent!
fixed slightly incorrect settings page (one of the options was visible when it didn’t need to be)
astosia just released version 2.2.0 of Tangent!
improved timezone settings so timezone list is pre-loaded on settings launch
astosia just released version 2.3.0 of Tangent!
another small timezone fix
astosia just released version 3.0.0 of Tangent!
V3 adds weather (Emery PT2 and Gabbro PR2 only at this stage)
astosia just released version 3.1.0 of Tangent!
reverted weather change due to errors in settings
astosia just released version 3.2.0 of Tangent!
putting weather back after fixing settings
astosia just released version 3.5.0 of Tangent!
V3.5 adds an experimental alert for Wet Bulb Globe Temperature, a measure of heat stress (PT2 and PR2). Alert is via 3 different icons. Small with 3 sunrays = a “yellow” alert level (plan outdoor exercise, use discretion), medium 4 sunrays = “red” alert (limit exercise & exposure), and large with five sunrays = “black” alert (not safe to exercise outdoors)
Hard for me to test where I live, so please give me feedback
astosia just released version 3.6.0 of Tangent!
fixed crash bug on non PT2/PR2 watches
astosia just released version 3.8.0 of Tangent!
V3.8 adds more languages for the date (let me know if this is incorrect for your location), and fixes a settings bug on aplite
astosia just released version 3.8.5 of Tangent!
minor updates to date formats to put them in uppercase
astosia just released version 3.8.6 of Tangent!
Fixed minor bug on positioning of QT icons on Emery & Gabbro (it was shifting slightly when BT was also disconnected). Also shifted BT/QT icons on other platforms to be consistent
astosia just released version 4.0.0 of Tangent!
Live preview added to settings page. Code tidy up: this release will reset settings to default
astosia just released version 4.2.0 of Tangent!
Added option to switch off numerals & show just major ticks instead. Added more granular controls to weather to show/hide elements. updated live preview
