Saucy Time! by Gardirop22 Studio
Saucy Time! is a playful, fully customizable watchface designed specifically for Pebble Time and Pebble Time 2. Instead of using a traditional font or pre-rendered number images, Saucy Time! builds its digits from custom geometry and renders them directly on your Pebble. Choose from six sauces: Ketchup, Mustard, BBQ Sauce, Mayonnaise, Guacamole and Beetroot, each with its own colors, highlights, shadows, drops and imperfections. Pick what goes with your sauce using three visual styles: Fries, Salad or Only Sauce. Then choose Morning, Night or Auto to change the atmosphere of the watchface. Auto automatically switches between the light and dark themes depending on the time of day. Time can also be customized with 12 or 24-hour format and optional leading zeros. The layout adapts accordingly, including a special composition for full hours. And it doesn’t have to stay still. Enable Shake It! and shake your Pebble to make the watchface react using its accelerometer. Fries scatter, salad pieces scatter, and Only Sauce responds with dynamically generated sauce-colored splashes before the composition settles back into place. Saucy Time! includes dedicated artwork and layouts for both Pebble Time and Pebble Time 2, designed around the native resolution of each display rather than simply scaling the same interface between devices. Six sauces. Three sides. Two displays. One very messy way to tell the time.
