Watchface: Radium 2 by Argentum Studio
:party: There’s a new watchface on the Rebble App Store!
:core-2-duo-black: Flint screenshots:
:party: Sterling Ely just released version 2.1 of Radium 2!
  • 40 color presets across five rows (Dark, Dark+, Light, Color, Special) - up from 24
  • 12 independent color slots: every element (hours, minutes, steps, battery, text, overlay, background) fully customizable
  • Cascade color picker: tap any parent swatch to set a whole group at once
  • Bug fixes: 12hr display, platform detection, settings persistence, overlay on round platforms
:party: Sterling Ely just released version 2.2 of Radium 2 (Radial Bar Graph)!
40 redesigned color presets — 5 new themes (Violet, Jungle, Lavender, Poison, Prism), 7 tweaked for better color theory, and a principled rule: unlit ticks always use a dark shade of the same hue family rather than neutral gray.
4 independently configurable info lines — each can show day, date, steps, distance, active calories, weather, battery %, or nothing. Two lines above the time, two below.
Live weather — current temperature in °F or °C pulled from Open-Meteo (no account or API key needed), with 6 custom weather icons: sun, partly cloudy, cloud, rain, snow, storm.
1-minute overlay mode — shake to show the time display, auto-hides after 60 seconds.
Leading-tick highlights — the current hour and minute ticks are independently colorable, bringing the total color slots to 17.
Two overlay sizes — Small (default) and Large, with Large as the default on Pebble Time 2 and Round 2.
Bug fix — the battery ring on rectangular watches was filling from the corner inward at low charge, leaving a dark gap at the 6 o’clock origin. Now fills correctly from the origin outward. Affected all rect platforms, color and B&W, since v2.0.
Bug fix — leading hour tick was off by one position on round watches in 12-hour mode.
Bug fix — active calories flame icon had a 1px overflow on the small overlay.
:party: Sterling Ely just released version 2.3 of Radium 2 (Radial Bar Graph)!
Solar Ring, new Info Fields, and a Bluetooth Disconnect Indicator, oh my!
Solar Ring Mode: A snazzy new outer ring option that tracks the sun instead of steps & battery. The right arc shows daylight remaining; the left arc shows time until sunrise. (stays alive on cached data if you lose phone connection)
New Info Line Fields:
:sun: Sunrise, Sunset, Daylight duration
:large_blue_diamond: Bluetooth Disconnect Indicator: shows a BT icon when your phone disconnects (blank when connected)
:heart: Heart rate: (BPM, on supported models)
:party: Sterling Ely just released version 2.3.1 of Radium 2 (Radial Bar Graph)!
Fixed: Large overlay size option now appears in settings on Pebble Time 2 and Round 2 (and defaults to on, matching the watchface)
Fixed: Heart rate display now works correctly on supported models
Minor: Health data (steps, distance, calories, heart rate) refreshes in sync with the minute tick
