astosia
December 31, 2025, 12:28pm
1
Phoenix Big by astosia
Phoenix Big is a customisable, easy to read, large font watchface using the Steelfish font. Shows optional weather, sunset/sunrise and steps
Features:
Auto-detection of 12h/24h based on your watch settings
Auto-translation of weekday supported for:
English, Spanish, German, French, Portuguese, Italian.
Day & Date and Battery complications
Optional display of Sunrise/Sunset time based on your current location (uses Suncalc, based on latitude/longitude from your phone’s gps) - on by default, switch off in settings
Moonphase
Step count (Time Series & Pebble 2 watches) - on Time Series, shows in Green if you are above your average step count, red if you are below.
Hour digits to shrink down when timelime quickview is visible (except PTR).
Optional Weather uses Open-Meteo by default, does not require an API key. If you prefer, you can switch to OpenWeatherMap 3.0, which does need an api key and subscription: there is a free tier. Select in settings whether to show current and/or forecast weather. Shake/Tap to change views:
Current weather shows conditions icon and current temperature
Forecast weather shows conditions icon and daily high|low temperature
Options:
Choose background and text colours
Bluetooth disconnect vibration warning and icon (no vibe in quiet time)
Quiet Time icon
Optional night theme colours between sunset and sunrise
astosia just released version 4.1 of Phoenix Big !
Added Emery/Pebble Time 2 support. Lots of code optimisation & clean up.
astosia just released version 4.2 of Phoenix Big !
fixed hour digit scaling on Chalk/Time Round
