Watchface: Nostalgic Commander by bemyak
:party: There’s a new watchface on the Rebble App Store!
:party: bemyak just released version 1.1.0 of Nostalgic Commander!
NEW
Full-weather strip for the wide middle slot: four captioned status chips in their own frame — COND TMP HUM PCP — with fills that appear only when a reading means something.
Humidity complication — colored only when the air is actually dry or sticky.
Precipitation complication — peak chance over the next 12 hours; while it’s raining (metric) it quietly becomes the live rate in mm.
High/Low — the day’s temperature extremes, in the top slots, colored by the high.
Config lists reordered into logical groups: Empty, system, date, health, weather.
A sunrise/sunset complication was built and then pulled before release — it crowded the top slots.
IMPROVED
Celsius always shows its sign (+22C); combined weather tightened to “SUN 72F”.
Less noise: neutral readings no longer wear status colors, so a fill always means something.
Fresh data faster: assigning a weather source fetches immediately, and after an app update the phone tops up older cached weather right away.
FIXES
App-message keys for new weather fields persist correctly across relaunches.
:party: bemyak just released version 1.2.0 of Nostalgic Commander!
What’s new in 1.2.0:
  • High/low slot now tracks the next extremes: today’s high until it passes, then tonight’s low and tomorrow’s high — the label flips to match.
  • Calmer colors face-wide: nothing lights up unless it needs your attention. Humidity is plain text, clean air no longer wears green, rain probability stays quiet until 50%.
  • Battery, one rule for chip and bar: calm above 39%, yellow under it, red under 20%, green whenever charging.
  • The standalone precipitation slot now highlights heavy rain like the centre strip does.
  • New installs default to the EGA blue panel theme; Auto by time of day is still an option.
:party: bemyak just released version 1.3.0 of Nostalgic Commander!
Add an option to disable vibration on phone disconnect
:party: bemyak just released version 1.3.1 of Nostalgic Commander!
  • Simplify HI/LO swapping logic
  • Improve disable vibration setting
:party: bemyak just released version 1.4.0 of Nostalgic Commander!
Added
  • Quiet Time indicator. A combined BT/QT window for top slots shows both phone states as Turbo Vision checkboxes ( [z]); bottom slots get a standalone QT window. State comes from quiet_time_is_active().
  • Wind complication. Direction as an 8-way arrow — including four custom diagonal glyphs patched into the bundled VGA font — plus sustained speed in your settings unit. Top slots show the unit (:up_right_arrow: 12 m/s), bottom slots save the space (:up_right_arrow: 12). The window bands yellow at strong breeze, red at gale (Beaufort rungs).
  • Combined Humidity + Precipitation source for top slots (HUM/PCP stubs over two tight fields).
  • Heart glyph on the BPM reading — 120​:heart:, drawn in the theme’s accent color.
Changed
-Two-field windows drop the slashes. HI/LO, AQI/UV, HUM/PCP and BT/QT now split their title into per-half frame stubs registered over the values. HI/LO’s value spells each number with its unit letter: +24C +18C.
-Settings slimmer on top slots: individual AQI, UV, Humidity and Precipitation are gone there — the combined readouts are the option.
-Centre weather strip: the temperature chip always lettered now (+22C), chip widened to fit it.
-Rename some settings to improve readability.
:party: bemyak just released version 1.4.1 of Nostalgic Commander!
Fixed
  • Combined BT/QT window in a top slot never painted its QT half — the drawer read the atomic Bluetooth source after the source renumbering, so [z] never rendered.
  • Slot settings showed [object Object] where the wind option should be: a botched options edit had nested the option object into its own label in config.json.
  • HI/LO rolled to tomorrow one hour early: the roll fired at the start of an extreme’s own hour, so a “now” reading inside that hour could disagree with the cell. Roll now happens when the hour ends.
