LumaTime by SupraorbitalStudios
SupraorbitalStudios just released version 1.1 of LumaTime!
Added configuration to launch upload page
SupraorbitalStudios just released version 1.2 of LumaTime!
Fixed a number of bugs, added ability to customize Date and Time text.
SupraorbitalStudios just released version 1.3 of LumaTime!
Migrated to new host with less connection issues for custom images
Added obfuscation for images (and self delete in 24h if no connection to download to local storage)
Added option to place text
Added text size options
Added text color options
SupraorbitalStudios just released version 1.8 of LumaTime!
Added option to reset to default image
SupraorbitalStudios just released version 2.0 of LumaTime!
- Added ability to save 3 pre-configured watches and re-load them later (instead of just the active one)
- Added a local configuration fallback that allows simple text positioning, sizing, and coloring even if the user is offline or the web hosted config page is unavailable.
SupraorbitalStudios just released version 2.1 of LumaTime!
Fixed the chose file issue by moving the edit page to a separate page that generates a code for you to get your watchface.
SupraorbitalStudios just released version 2.2 of LumaTime!
Small fix with reseting default image not loading correctly
SupraorbitalStudios just released version 2.3 of LumaTime!
Bugfix for new watchfaces overriding the first slot
SupraorbitalStudios just released version 2.4 of LumaTime!
Fixed frequency selection not working
SupraorbitalStudios just released version 2.5 of LumaTime!
Fixed bug that prevented reactions from triggering after new frequency options were added
SupraorbitalStudios just released version 2.6 of LumaTime!
Fixed fault config link
SupraorbitalStudios just released version 2.8 of LumaTime!
Split the config and edit page in two to not have to load the whole editing logic when just opening the pebble config.
Fix for crash if you would load 2 images at the same time too quickly
Performance improvement on text outline drawing
Small improvements to edit web page
SupraorbitalStudios just released version 2.9 of LumaTime!
Improved handling of failed image transfer from the pebble app to the watch.
Other small bugfixes
SupraorbitalStudios just released version 3.0 of LumaTime!
Updated loading animation
SupraorbitalStudios just released version 3.1.0 of LumaTime!
Update offline edit, polished web edit, battery improvements, preloaded faces on watch
SupraorbitalStudios just released version 3.2.0 of LumaTime!
SupraorbitalStudios just released version 3.4.0 of LumaTime!
Update to offline settings
