Giant Clock by BV Designs
Powered by KiezelPay: $1.99 + local taxes
Displays the time in a GIANT easy-to-read format (actually the very largest system font available for each device). The large type will surely be a hit with visually-challenged users.
Choose the fitness stats you would like to see in the settings menu: steps, heart rate, calories, distance, active minutes and floors climbed (applicable devices only). The distance displays miles or km based on user profile.
In order to display the goal progress for steps, heart rate, calories, distance (miles or km) and active minutes, it is necessary to add your personal goals in the settings menu as it is not possible to get these from your profile.
The bluetooth icon appears when connected and disappears when disconnected.
Features:-
Date format options.
Fitness status circle, displaying how far you are from goal.
Battery level status bar, with colours determining the level.
Colour configurable.
Weather:
Provided by OpenWeatherMap. Only 2 weather updates per day, so option to enter your own weather API key for more frequent updates. Choice of temp unit in settings - C or F.
BV Designs just released version 1.1 of Giant Clock !
1.1.0: Improved weather function.
