ForecasWatch 2 by Matt Rossman
Matt Rossman just released version 1.25 of ForecasWatch 2!
Battery now shows charging indicator
Matt Rossman just released version 1.26 of ForecasWatch 2!
Forecast graph now shows hatch shading between sunset and sunrise to distinguish day and night. Day/night shading is on by default and can be turned off in the Weather section of the watchface settings.
Privacy-respecting weather telemetry is now enabled, see README for details.
Matt Rossman just released version 1.27 of ForecasWatch 2!
If you live in a very hot or cold place, you’ll no longer see ellipses (…) when low/high temperature labels on the weather graph get too wide.
Matt Rossman just released version 1.28 of ForecasWatch 2!
Skip weather fetch when watch is disconnected
Matt Rossman just released version 1.29 of ForecasWatch 2!
Adds opt-out for telemetry in settings (but pls keep it on so I can make the app better)
Matt Rossman just released version 1.30 of ForecasWatch 2!
GPS falls back to cached coordinates (up to 24 hours old) in the event of an error.
Matt Rossman just released version 1.31 of ForecasWatch 2!
Forward geocoding for manual location overrides now caches results and uses exponential backoff to reduce excessive error loops. If a weather fetch fails, the error is now visible on the Settings page.
Matt Rossman just released version 1.32 of ForecasWatch 2!
Memory improvements: bitmaps now lazy-load and layers are flattened (particularly around the calendar text) to reduce heap usage.
Other fixes: the watch can now check/request fresh weather data from the phone on boot in the event that it desyncs from the phone’s periodic weather deliveries. Also, geocode backoff skips unnecessary fetch attempt reporting.
Matt Rossman just released version 1.33.0 of ForecasWatch 2!
Pebble Time 2 is now natively supported. Enjoy your favorite watchface, optimized for the larger display.
Matt Rossman just released version 1.34.0 of ForecasWatch 2!
Migrates default weekend and holiday colors to red (folly).
Matt Rossman just released version 1.35.0 of ForecasWatch 2!
Forecast graph now shows precipitation amount bars in addition to the chance of rain.
Also fixes night shading in precipitation regions on B&W watches.
Matt Rossman just released version 1.36.0 of ForecasWatch 2!
Hotfix to prevent temporary rendering quirks from persistence key reordering
