Watchface: Din clean by Christophe Jeannette
:party: There’s another cool watchface on the Rebble App Store!
:party: Christophe Jeannette just released version 1.29 of Din clean!
• Added weather graph with 12-hour forecast and 3-day outlook accessible via tap
• Integrated MET Norway API for free weather data (no subscription required)
• Optimized memory usage and reduced graphics size by 50-70%
• Improved code stability with full module refactoring
• Enhanced battery efficiency with smarter weather update scheduling
:party: Christophe Jeannette just released version 1.30 of Din clean!
Settings panel fix + code cleaning
Second panel option
:party: Christophe Jeannette just released version 1.31 of Din clean!
Fix for Pebble Time
:party: Christophe Jeannette just released version 1.32 of Din clean!
Fixes for non OG pebbles
:party: Christophe Jeannette just released version 1.33 of Din clean!
Three icons have been added to persistent memory.
:party: Christophe Jeannette just released version 1.34 of Din clean!
Graphical hours are now stored in memory
:party: Christophe Jeannette just released version 1.35 of Din clean!
Cleaning up useless resources
:party: Christophe Jeannette just released version 1.36 of Din clean!
Icons png are converted in 2 bits
:party: Christophe Jeannette just released version 1.37 of Din clean!
Weather icons: Transparency fixed
:party: Christophe Jeannette just released version 1.38 of Din clean!
Each icons are reviewed to have the correct memory format
:party: Christophe Jeannette just released version 1.39 of Din clean!
Fix Basalt weather graph crash by optimizing stack usage and completing temperature curve display
:party: Christophe Jeannette just released version 1.40 of Din clean!
News feed integration
:party: Christophe Jeannette just released version 1.41 of Din clean!
12h format for imperial changes
:party: Christophe Jeannette just released version 1.42 of Din clean!
News feed stability improvements
:party: Christophe Jeannette just released version 1.43 of Din clean!
Added “Require double tap for panels” option
Words speed down
:party: Christophe Jeannette just released version 1.44 of Din clean!
Increase weather icon timeout by 10 minutes to prevent disappearance during weather fetch failures.
:party: Christophe Jeannette just released version 1.45 of Din clean!
New Features
Custom RSS Feed
Added a text field for custom RSS feed URL in the settings
3 preset buttons: Breaking News, Gaming, Finance
Dynamic extraction and display of the channel title on the splash screen
Full UTF-8 and HTML entity decoding support for French accents
Spritz Speed Reading (RSVP)
Implemented OpenSpritz algorithm with pivot letter calculation
Centered word display with bold effect on the pivot letter
Horizontal guide lines, central outline circle, and vertical line
Variable delays based on punctuation (periods, commas)
Configurable speed (default 160ms/word)
Improvements
Reduced news activation cooldown from 30s to 5s
Automatic RSS fetch on startup if news is enabled
Immediate channel title update when RSS URL changes
Channel title sent even when using cached news
:party: Christophe Jeannette just released version 1.46 of Din clean!
News feed UI changes
Stability improvements
:party: Christophe Jeannette just released version 1.47 of Din clean!
Wind values and icons
Fix for RSS news words getting stuck
Weather graph UI slightly modified
Wind indicator added
