Dashboard by Lignite
Lignite just released version 1.4 of Dashboard!
- Add detection of PebbleOS bug where persistent storage of watchface gets wiped
- Replace trial ended ‘error’ screen with screen describing this as a PebbleOS bug and a link to Lignite.io/e420 with instructions on how to report this bug and fix your watchface
- Fix settings not loading on legacy iOS Pebble app
- Fix crash due to empty string in top right data quadrant
- Improve accuracy of titles for custom date formats
Lignite just released version 1.5 of Dashboard!
- Add support for timeline pins (UnobstructedArea), so Dashboard won’t get blocked at the bottom anymore!
- Add full support for Pebble Time 2
Lignite just released version 1.6 of Dashboard!
- Fix time sometimes being X hours ahead/behind, where X is the difference between your local timezone and UTC
Lignite just released version 1.7 of Dashboard!
The “Buttery Smooth Settings” update!
- Add support for automatic restoration of settings when reinstalling the watchface
- Fix settings sometimes being lost on the settings page
- Fix reset settings button not working in some cases
- Improve detection of Pebble persistent storage being wiped and attempt to automatically restore all storage from phone app backup silently
- Improve watchface persistent-storage related error handling, in rare cases where it cannot be silently restored
- Improve settings page error handling when settings can’t be restored from mobile app
- Improve speed of live settings updates
- Remove need to set which Pebble mobile app you are using before being able to use settings
Lignite just released version 1.8 of Dashboard!
- Fix time and weather boxes missing some pixels on Pebble Time 2 (PT2)
- Fix colour settings sometimes not syncing to settings page correctly
- Fix settings page occasionally crashing
- Improve alignment of time numbers, AM/PM, and Bluetooth indicator on PT2
- Increase spacing between caption letters by 1px on PT2 for better readability
Lignite just released version 1.9.0 of Dashboard!
- Add support for Pebble Round 2
- Improve text content of some weather conditions
- Fix text sometimes overflowing on top and bottom data layers
Fix temperature value of 99° displaying as -99°- Fix temp & condition stat not respecting preferred temperature format
- Increase top and bottom stat buffer size by 4 bytes each (should result in fewer very long stats being truncated)
Lignite just released version 1.9.1 of Dashboard!
- Fix AM / PM indicator being stuck on AM for Pebble Round 2 (thank you, Kasey!)
- Fix weather data showing when watch has not yet synced the time (and therefore would not actually know if that weather data was valid)
- Fix partly cloudy at night displaying text “Sun & Clouds” (now says “Some clouds”)
- Do not vibrate on watchface factory reset if Quiet Time is active
- Reduce amount that the watchface relies on staying connected to the phone for settings updates, improving battery life
