Civic Segments by RandyTheSilly
A highly configurable clone of the beautiful 8th gen Honda Civic driver display assembly. The time font was carefully crafted to resemble the segmented display on the 8th gen Civic speedometer as closely as possible, using the full resolution of the PT2 to achieve maximum accuracy. The fuel gauge tracks your battery (including a low fuel indicator) and the temperature gauge gives you a relative idea of the temperature at your location. With a flick of your wrist, you can be reminded of the date.
The face features built-in color presets for standard and Si Civics, as well as presets to match the blue/red colors of some PT2 models/bands. The dark presets take advantage of the RGB backlight for a unique effect.
Want something more personal? Everything is individually configurable, including the color of everything you see, from the tiny accent lines on the side bars to the backlight LED. Beyond colors, the range of the temperature gauge is configurable as well as what battery percentage is worthy of a low fuel warning.
Some optional features include the display of unlit segments behind the time, timeline peek support (minutes shrink to fit the timeline event info), shake to see the date (configurable timeout), and hour/month color shift on BT disconnect. Disabling optional features does actually improve efficiency (disabling peek support avoids loading the second font, setting date timeout to 0 unsubscribes from accelerometer events, etc.).
Warning light legend:
- Lit “E” and “F” icons: low fuel (battery)
- Lit “C” and “H” icons: temperature fetch failure
- Lit hour/month digits: BT connection lost (this feature is off by default)
RandyTheSilly just released version 1.0.1 of Civic Segments !
Retry temperature fetch when API is temporarily overloaded
Fixed inaccurate help text for BT indicator in Clay settings
