lazydevs just released version 1.4.0 of Wristotle!
v1.4.0
- Find my phone now rings loud — full alarm volume, with vibration — so you can hear it even when your phone’s media volume is muted. Tap, Stop, or swipe the notification to silence it.
lazydevs just released version 1.4.1 of Wristotle!
v1.4.1
- Fixed: dictating something that merely mentions your phone — “make a note to find my phone charger”, “remind me to find my phone” — no longer rings the phone by mistake. Find My Phone now only triggers when you actually ask to find it.
Needs the Wristotle Android companion app v1.14.2 or newer for the full fix.
lazydevs just released version 1.5.0 of Wristotle!
v1.5.0 — Saved codes on your wrist
Keep your loyalty cards and QR codes on your watch. Save them in the Wristotle phone app, then pull one up full-screen at the checkout — scannable even with your phone away.
• New Codes screen — long-press UP → Codes, pick a card, and it fills the screen with the name on top and the backlight on
• Recall by voice — say “show my QR code” or “show my clubcard”
• Supports QR, Code 128, EAN-13 and UPC-A
• Works offline — codes are cached on the watch
Requires the Wristotle companion app (v1.15.0+) to add, edit, and sync your codes.
lazydevs just released version 1.5.1 of Wristotle!
Wristotle Watch v1.5.1
Two fixes for saved codes:
- A code you pull up by voice (“show my clubcard”) now stays on screen long enough to scan instead of disappearing after a few seconds. With the companion app you can set exactly how long it stays, or keep it up until you press Back.
- You can now bind a watch button to your saved codes. In the companion app, Settings > Watch > shortcuts, set a long-press (or Select) to Codes to jump straight to the list.
Pairs with Wristotle Companion v1.16.1.
lazydevs just released version 1.6.0 of Wristotle!
Wristotle Watch v1.6.0 - Failed actions stay on screen
Failed and unrecognized voice actions no longer disappear like a successful one. When something doesn’t work, the result now stays on the watch until you press Back, and it shows the time you asked (“Tried at 3:42 PM”) so you can rebuild a timer or alarm from it. Successful actions still clear themselves after the usual read window, and cancelling an action on purpose still exits cleanly.
Pair this with Companion v1.17.0 or newer, which sends the watch the new failure signal.
lazydevs just released version 1.7.0 of Wristotle!
Wristotle Watch v1.7.0 - Ask Agent follow-ups
Ask Agent now remembers your recent turns, so follow-up questions work. Ask “what’s the weather in Rabat?” then just “and tomorrow?” and it keeps the thread instead of treating each question as a fresh one. This pairs especially well with the hands-free “Ask Agent only” mode.
While a conversation is live, the watch shows “Context on” in the hint bar so you know your turns are linked. Say “new”, “forget” or “reset” to start over, and the context clears itself after a while idle.
The conversation history lives only on your phone (never on the watch), so there’s no memory cost on the watch side.
Needs Companion v1.19.0 or newer.
lazydevs just released version 1.8.0 of Wristotle!
Wristotle Watch v1.8.0 - On-watch timers
Timers can now run on your Pebble instead of your phone. Say “set a timer for 10 minutes” and the watch counts down and buzzes when it’s up, even if you’ve closed the app. A dismissable “Time’s up!” screen appears when it fires.
Turn it on in the companion app under Settings > Watch > “Run timers on the watch” (off by default; without it, timers still open your phone’s clock as before). Timers and alarms run independently, each with its own screen.
Needs Companion v1.20.0 or newer.
