Plane Map by ZeeCas
There’s another cool watchapp on the Rebble App Store!
ZeeCas just released version 1.4 of Plane Map!
- Fixed location of planes when zooming
- Increased maximum zoom
- Now zooms by 25nm past 50nm
- Stores zoom state in local storage
- Beginnings of compass support
- Added background to plane count
- When no planes are present, say so in list view
- Reduced details view font size
- Lowered refresh time from 5s to 3s
ZeeCas just released version 1.5 of Plane Map!
- Fixed compass
- Hopefully fixed issues with map being cut off around the edges
- Hopefully fixed zoom levels not being remembered properly
- Changed detail text to bold to increase readability
ZeeCas just released version 1.6 of Plane Map!
- Allows for the maximum number of planes to be configured
- Adds indicator when max number of planes being displayed
- Allows for zooming up to 1nm
Amazing app! Now I don’t have to get out my phone every time someone is buzzing my house!
ZeeCas just released version 1.7 of Plane Map!
- Added Favorites!
Flights can be added to favorites by either manually specifying the tail number or registration in the app, or by using the select button on the details screen of a given flight. Favorited flights will be highlighted on the map, as well as in the list view!
On my PT, when I Favorite an aircraft, it cuts off the Speed at the bottom of the page. You could just remove that Not Favorite text at the top and place a star to the right of the reg#.
ZeeCas just released version 1.8 of Plane Map!
- Changed how favorites are displayed
- Added a help menu
This app just gets better and better!
ZeeCas just released version 1.9 of Plane Map!
- Added toggle for using MPH for speed
Works great on my PT, can’t wait to see it on my PT2!
ZeeCas just released version 1.10 of Plane Map!
Added support for Round, Round 2, and Time 2
ZeeCas just released version 1.11 of Plane Map!
- Added small zoom popup
- Added hold to zoom
- Added toggleable radar sweep
It seems it doesn’t work on a OG Pebble Steel. Regardless of the zoom level, no planes appear. It shows “loading …” at the bottom. When pushing the middle button, it says " No planes detected”. I am in Munich, Germany, there should be planes around.
