pl8s by cmalec
pl8s (“plates”) is a barbell percentage and plate calculator for your wrist. Enter a training max once and it shows each working weight with the exact plates to load per side, so the math is done before you walk to the rack.
Percentages: 90/80/70/60/50 in 10% steps, or 5% steps from 90 down to 60
Exact loads: every row is rounded to a weight your plates can actually build on a 45 lb Olympic bar
Plate glyph: the plates for each row are drawn side view, heaviest first
Your gym’s plates: tell it how many of each size are on the rack (0-10 per side, or 99 for unlimited) and each weight snaps down to a load those plates make
Quick to change: nudge the max 5 lb at a time, hold SELECT for the on-watch settings wizard, or use the settings page in the phone app
Remembers everything: max, step size and plate counts survive leaving the app
Plates are colored as 55 red, 45 blue, 35 yellow, 25 green, 15 pink, 10 white, 5 cyan, 2.5 grey: a disc with its weight printed on the face on the large screens, a side-view bar on the compact ones, and the same drawing in black and white on 1-bit displays.
Everything runs on the watch: no phone needed at the gym.
Gabbro screenshots:
cmalec just released version 1.0.1 of pl8s !
1.0.1 — The launcher icon is now black, so it’s visible in the watch’s app list. Also fixes the results rows shifting after changing the plate step on the larger displays.
cmalec just released version 1.1.0 of pl8s !
backlight: release after 30 s without a button press
