jLynx
January 4, 2026, 6:34am
1
Phone Battery Monitor by jLynx
Never wonder about your phone’s charge level again! Monitor your phone’s battery directly from your Pebble watch - perfect for when your phone is charging in another room.
Key Features:
• Real-time battery level display with large, easy-to-read percentage
• Visual battery indicator with color-coded status (green/yellow/red)
• Animated charging indicator - see at a glance when your phone is plugged in
• Instant updates when battery level or charging status changes
• Manual refresh with SELECT button
• Vibration alert when your phone reaches 100% charge
• Current time display
• Works on all Pebble models
How It Works:
Simply install the app and it will automatically connect to your phone. The watch face shows your phone’s battery percentage, charging status, and a visual battery icon that fills up as your phone charges. The lightning bolt animation lets you know when charging is active.
Perfect For:
• Monitoring charging progress from another room
• Keeping track of your phone’s battery without checking it constantly
• Getting notified when your phone is fully charged
• Peace of mind when you can’t see your phone
Requirements:
• Pebble watch (all models supported)
• Smartphone with Battery Status API support (most modern iOS and Android devices)
Stay connected and never miss a charge cycle again!
jLynx just released version 1.1 of Phone Battery Monitor !
Fixed the contrast on colour screens
Fixed the charging indicator not being visible if the phones battery percentage was less than 50%
jLynx just released version 1.2 of Phone Battery Monitor !
Updated the ability to set & disable full charge notification
