Watchapp: Pebble OwnTone Remote by ChillyDown
:party: ChillyDown just released version 1.2 of Pebble OwnTone Remote!
Version 1.2 (2026-02-23)
  • Fix crash on Aplite when scrolling the Random results list
So excited to have built and published an app!
:party: ChillyDown just released version 1.3 of Pebble OwnTone Remote!
Version 1.3 (2026-02-24)
  • Outputs: single-pressing an active speaker now opens volume controls directly, without changing its state
:party: ChillyDown just released version 1.4 of Pebble OwnTone Remote!
Version 1.4 (2026-03-10)
  • Raise max search/random results on Aplite from 4 to 8 (matching other platforms)
  • Remove long-press shortcut to player window on Aplite (icons displayed incorrectly when accessed this way)
:party: ChillyDown just released version 1.5 of Pebble OwnTone Remote!
v1.5 (2026-03-17)
  • Player layout redesign: Dynamic text measurement using text_layer_get_content_size() for accurate sizing
  • Text containers now sized exactly to rendered content height — no extra padding inside boxes
  • Divider lines between track/artist/album
  • Entire text block vertically centered on screen
  • Overflow handling: album truncates first, then artist, then track
  • Splash screen minimum display time halved (2000ms → 1000ms)
:party: ChillyDown just released version 1.6 of Pebble OwnTone Remote!
v1.6 (2026-03-17)
  • Fix descender clipping on track/artist text (G, g, p, y no longer cut off)
:party: ChillyDown just released version 1.7 of Pebble OwnTone Remote!
v1.7 (2026-03-17)
  • Fix player layout not reflowing correctly when track changes
:party: ChillyDown just released version 1.8 of Pebble OwnTone Remote!
Version 1.8 (2026-03-20)
  • Fix output volume window icons missing on Aplite: free outputs MenuLayer before volume window loads to stay within 24KB heap
  • Free player window bitmaps when hidden on all platforms, reducing peak heap usage
:party: ChillyDown just released version 1.9 of Pebble OwnTone Remote!
Version 1.9 (2026-03-21)
  • Fix radio streams in player window: show track title at the top and station name at the bottom
:party: ChillyDown just released version 1.10 of Pebble OwnTone Remote!
Version 1.10 (2026-04-04)
  • App auto-close: after the player window closes, the app exits to the watchface if no buttons are pressed within a configurable timeout (default: 5 minutes)
  • Resets on any button press in the main menu or outputs windows
  • Configurable via the Battery Optimization section in settings
:party: ChillyDown just released version 1.11 of Pebble OwnTone Remote!
Version 1.11 (2026-04-09)
  • Fix player action bar icons sometimes missing on Aplite (prev/next/play/pause/volume/ellipsis)
  • Fix heap exhaustion on Aplite: MenuLayers in list windows (main menu, favorites, queue, random, results) now freed when hidden, preventing child windows from running out of memory
  • Fix brief main menu flash on Basalt before the player window appears at startup
:party: ChillyDown just released version 1.12 of Pebble OwnTone Remote!
Version 1.12 (2026-04-11)
  • Search: strip punctuation and normalize whitespace before querying the server, improving match quality
  • Search: skip the API call and return empty results immediately if the cleaned query is empty
:party: ChillyDown just released version 1.13 of Pebble OwnTone Remote!
Version 1.13 (2026-04-15)
  • Player: volume level displayed as a number in the center action bar slot when volume mode is active and UP or DOWN is pressed; updates on each press and disappears when volume mode times out (both Aplite and Basalt)
  • Queue: fix current track appearing as the last item with no upcoming tracks on Aplite; now correctly shows up to 4 previous and 5 upcoming items on all platforms
  • Memory: major internal refactor to reduce peak heap usage on all platforms — list-based windows (queue, results, outputs, random) now share a single reusable window layer instead of each owning a persistent MenuLayer, freeing significant RAM when navigating between screens; standalone splash window removed from Basalt (replaced by a brief logo overlay in the player screen)
:party: ChillyDown just released version 1.14 of Pebble OwnTone Remote!
Version 1.14 (2026-04-30)
  • Player: fix missing music info text in the player window — track/artist/album now reliably display after recent fixes; show a placeholder when metadata is unavailable
:party: ChillyDown just released version 1.15 of Pebble OwnTone Remote!
Version 1.15 (2026-07-05)
  • Platform: Add support for Pebble 2 Duo (flint) and Pebble Time 2 (emery) — voice search (dictation) now works on these devices.
  • Haptics: Fix missing vibration on Flint for long-press volume controls; use a short pulse for consistent feedback across cores.
  • Misc: Keep query sanitization (strip punctuation / normalize whitespace) to improve voice search results.
:party: ChillyDown just released version 1.16 of Pebble OwnTone Remote!
Version 1.16 (2026-07-09)
  • Config: persist player auto-close timeout set in the configuration page; settings passed from the Pebble JS webview now pre-populate fields so the player timeout no longer reverts to 30 seconds.
:party: ChillyDown just released version 1.17 of Pebble OwnTone Remote!
Version 1.17 (2026-07-20)
  • Config: Add vibration setting to the configuration page. Options: Default (40ms), Strong (80ms), Off. Settings persist in the webview and are sent to the watch when the Pebble app connects.
:party: ChillyDown just released version 1.18 of Pebble OwnTone Remote!
Version 1.18 (2026-07-20)
  • Release: Bump to 1.18 for publishing; minor fixes and release preparation. Includes vibration configuration and related fixes.
