Pebble Golf by Chris Snyder
Chris Snyder just released version 0.10.0 of Pebble Golf!
- Score entry: the distance-to-green now updates live as the GPS fix moves while the screen is open (it previously froze at its open-time value).
- Score entry: editing an already-scored hole no longer resets its strokes/putts to par (or zero). it now starts from the entered score.
- Score entry: larger center yardage and larger front/back numbers (small “F”/“B”
prefixes), with tightened spacing.
Chris Snyder just released version 1.0.0 of Pebble Golf!
First stable release.
- Score keeping is now inline on the hole view. Press or tap a stat box to edit strokes/putts (and par on custom holes) in place, no separate screen.
- The yardage display is bigger and cleaner: a large center distance with front/back below it, anchored to the screen edges.
- Hole-map tap-to-measure that shows both the distance to your target and what’s left to the green, and a live you-marker that tracks as you walk.
Chris Snyder just released version 1.1.0 of Pebble Golf!
You can now start a full round right from the watch with no phone in sight: pick “Custom round,” choose 9 or 18 holes, and enter par as you go. Getting to the hole map is quicker, just long-press UP from the hole view. Score entry now gives you a little haptic feedback when you start and when a hole saves, and tap-to-measure on the map is on by default. Plus tidied-up button hints across every screen and a few small visual fixes.
Chris Snyder just released version 1.2.0 of Pebble Golf!
This one is all about the tees. The tee picker now lists tees shortest to longest, and when a tee is rated for both it shows the men’s and women’s course rating/slope side by side. Your chosen tee’s colour now rides along as a small swatch next to the hole number on the hole screen, so a glance tells you which tees you’re playing. Changing your tee mid-round drops you right back to the hole instead of the setup screen. And a stale-data glitch is fixed: quickly switching courses no longer briefly shows the previous course’s tees
Chris Snyder just released version 1.3.0 of Pebble Golf!
Pebble Golf now runs on three more Pebbles, and it speaks six languages.
Now runs on Pebble Time and Time Steel, Pebble 2, and Pebble 2 Duo, not just the Pebble Time 2. Every screen, the scorecard, and the hole map were adapted to the smaller and black-and-white displays (the small watches are button-only).
The whole app, watch and phone settings, is now translated into French, German, Spanish, Italian, and Portuguese. It follows your watch and phone language automatically, so there’s nothing to set.
Round Setup is now two steps (pick which holes, then your starting hole) so neither is cramped on the smaller screens.
The Pebble Time 2 hole map shows finer geometry now (about 50% more detail in the greens, bunkers, and fairways).
Chris Snyder just released version 1.4.0 of Pebble Golf!
This one is for the round watches.
Now runs on the Pebble Time Round and the new Pebble Round 2, with every screen laid out for the circular display (touch on the Round 2, buttons on the Time Round).
Error screens now use the standard Pebble warning icon.
The round-setup hole step is now titled “Select holes”.
Round-watch fixes: the over/under-par badge is centered in its pill, the confirm message no longer gets cut off, and the resume flag is no longer clipped.
Chris Snyder just released version 1.5.0 of Pebble Golf!
Use it as a pure rangefinder now, if that’s your thing.
- New Scorekeeping setting: turn it off for a distances-only rangefinder.
- Smarter auto-advance: moves to the next hole once GPS sees you’ve reached the tee.
- The mid-round scorecard is view-only, so SELECT can’t end your round by accident.
Chris Snyder just released version 1.6.0 of Pebble Golf!
Course data fixes.
- Scorecards load again after the golf data source changed its format.
- Nine-hole courses play as nine holes, not eighteen par 4s.
- A round in progress keeps its yardages and map through an app update.
- Course search no longer labels every result “18 holes”.
Chris Snyder just released version 1.7.0 of Pebble Golf!
Your watch can now suggest a club. Thanks to @bndki for the idea!
- Club suggestions (experimental): enter your distances on the phone and get a club beside the yardage.
- New My bag page lists every club, longest first, with the suggested one highlighted.
- Fixed a crash on Pebble Time, Time Round and Pebble 2 in French, German, Spanish, Italian and Portuguese.
- Some newer translations no longer show up in English.
