Watchapp: Notification Center by matejdro
:core-2-duo-black: Flint screenshots:
:party: matejdro just released version 1.2 of Notification Center!
  • fix scrolling indicator not stretching edge-to-edge
  • fix app jumping to first notification on list change
  • fix periodic vibration triggering when turned off
After improvements in version 1.2, I can now switch over from the on-watch Notifications app, just remember to go into the Settings then Notifications and in Filter, select Allow Phone calls Only. I also changed Quick Launch to choose Notification Center.
NC does not handle phone calls, so you might want to set the filter to let the phone calls through.
Thanks, I edited my previous post.
:party: matejdro just released version 1.13 of Notification Center!
add show image
:party: matejdro just released version 1.20 of Notification Center!
  • only trigger periodic vibration from unread notifications
  • fix “no notifications” sometimes not auto-closing
:party: matejdro just released version 1.31 of Notification Center!
Lots of bug fixes
Having trouble sending the notifications to my PT. In Notification Access, I hit Grant but my PT is not listed.
You do not need to select your watch here, just select anything on that list.
Great, fixed my problem, working now!
:party: matejdro just released version 1.40 of Notification Center!
Fixed cut off text
:party: matejdro just released version 1.51 of Notification Center!
fix periodic vibration sometimes not triggering
:party: matejdro just released version 1.70 of Notification Center!
Features
#24 - notification: add hide from watch action (9741727a)
#24 - add restore hidden notifications button (de4c7742)
#27 - only close to last app when needed (78662a9e)
#25 - add disable wrap around setting (7042fa80)
#33 - add backlight option (45b23e4b)
#68 - notification: add no history rule (c2a481c7)
#45 - notification: add priority rule (45ea0a2f)
#47 - add image zoom (4113d276)
Bug Fixes
tasker: error message mentioning Catapult (1ca732c9)
#35 - watch: do not vibrate with quiet time active (c82d7cfe)
#86 - home: add legacy permission grant (09146750)
home: hide instructions popup after granting (db2199b5)
Thanks, I appreciate the many improvements in your v1.70 release!
:party: matejdro just released version 1.82 of Notification Center!
notification sometimes unread at startup
:party: matejdro just released version 1.91 of Notification Center!
make the large status bar clock GOTHIC_24_BOLD
