mcbroken by nubbybubby
A mcbroken client for Pebble smartwatches. Now you can check if the ice cream machine is down on your wrist! This app is still kinda rough, but it works well enough on my machine™ so I’m posting it now.
Nearby shows up to 5 McDonald’s locations within a 5-mile (8.04 km) radius from your current location, sorted from closest to farthest, and Saved shows all of your saved locations (duh) that you’ve added in the app settings. You can save up to 5 locations. (adding locations on my app is kinda jank but it works)
nubbybubby just released version 1.1 of mcbroken !
nubbybubby just released version 1.2 of mcbroken !
The Nearby/Saved locations header is now fixed to the top of the screen when you scroll down
Backlight now turns on automatically when it’s done loading
The app now makes the watch vibrate when it’s done loading if it took longer than 7 seconds to load
nubbybubby just released version 1.21 of mcbroken !
changed the URL the app points to
nubbybubby just released version 1.30 of mcbroken !
added stats menu
fixed some bugs related to loading
