Watchapp: Instant Timer by howeaj
:party: There’s another cool watchapp on the Rebble App Store!
Screenshot 0
Screenshot 0
Screenshot 0
Screenshot 0
Screenshot 0
:core-2-duo-black: Flint screenshots:
Screenshot 0
:core-time-round-2-14-rose-gold: Gabbro screenshots:
Screenshot 0
:party: howeaj just released version 1.2 of Instant Timer!
Clarify display when update rate is reduced from seconds to minutes (“–s” instead of “…”)
:party: howeaj just released version 1.3 of Instant Timer!
Always allow 1min increments, rather than forcing 5 beyond 30.
Shorten glance text to fit without scrolling on smaller screens.
:party: howeaj just released version 1.4 of Instant Timer!
Return to per-second updates whenever the green or red ring is within 3 minutes of completion
:party: howeaj just released version 1.5 of Instant Timer!
Clarify app exit status with trash/save screenwipe
:party: howeaj just released version 1.6 of Instant Timer!
Fix save icon on black&white platforms.
Fix app launch icon on OG Pebble.
:party: howeaj just released version 1.7 of Instant Timer!
Fix crash on Pebble Time 2!
:party: howeaj just released version 2.0.0 of Instant Timer!
  • Touch control!
    • Touch and drag to select hours then minutes; this clears all state and starts a new timer/alarm.
    • Start touching from the middle to set a timer duration, or from the edge to set an alarm time
    • To cancel, finish touching in the middle or don’t select any minutes
  • Configuration options:
    • Colours / themes
    • Touch enable/disable and timeout
:party: howeaj just released version 2.1.0 of Instant Timer!
  • Ignore very short touches (configurable)
  • Bugfix incorrect scheduling of wakeup timer on exit-and-delete
  • Bugfix angle selection indicator updates while touching in the middle
:party: howeaj just released version 2.2.0 of Timer - Instant Timer!
  • Increase size of the central touch zone
  • Touches reveal seconds if hidden (synced with backlight)
  • New user-requested config options:
    • Swap duration vs alarms on the outer vs inner touch zone
    • Retain elapsed time when setting duration with touch
:party: howeaj just released version 2.2.1 of Timer - Instant Timer!
  • Change the default “Affected Values” touch config to “Set Duration, Keep Elapsed” to match button controls
:party: howeaj just released version 2.3.0 of Timer - Instant Timer!
  • Config alarm vibes: double, long or short
  • Add missing start/stop vibe for exit-and-delete
:party: howeaj just released version 2.3.1 of Timer - Instant Timer!
  • Bugfix minutes touch input timeout after a touch below the minimum threshold
  • Bugfix slow elapsed update for touch “clear elapsed” mode
:party: howeaj just released version 2.4.0 of Timer - Instant Timer!
  • Touch timer duration now set with a single touch; just select minutes and “wind up” (circle clockwise) to increase hours.
  • Ignore very short finger lifts during touch hours selection
  • New config options:
    • Revert to the two-touch hours-then-minutes method.
    • Turn off the touch screen while inactive; turns on for 3s after a button press or accel shake/tap, like the system backlight
    • Minimum finger lift duration
i tried the other timer app, and it want intuitive and fast. didnt know how I would have fixed them though. tried this one - I love it. UI UX genius.
:party: howeaj just released version 2.5.0 of Timer - Instant Timer!
  • Touch timer seconds precision; enable by “winding down” anticlockwise from 0.
:party: howeaj just released version 2.6.0 of Timer - Instant Timer!
  • Pressing Up or Down while the alarm is ringing now Restarts or Delete&Exits the app, rather than just clearing the alarm.
  • New config options for power saving (defaults to the previous hardcoded values). Can force always-seconds-updates.
:party: howeaj just released version 2.6.1 of Timer - Instant Timer!
  • Sync per-minute updates to timer/stopwatch minutes instead of wallclock minutes.
  • Fix seconds still being shown on each timer loop when timer threshold is 0.
:party: howeaj just released version 2.6.2 of Timer - Instant Timer!
  • Fix touch-to-wake not enabling seconds display; all “backlight on” events now show seconds.
:party: howeaj just released version 2.6.3 of Timer - Instant Timer!
  • Fix app glance in launcher (workaround for suspected mobile app installer bug)
