hb MabelAI by Alan Johnson
There’s another cool watchapp on the Rebble App Store!
Your AI powered assistant on a Pebble Smartwatch. Speak questions to Mabel and she will fetch your answer from one of 3 configurable AI partners.
Features:
Voice-to-text input using Pebble’s built-in dictation (requires mic: Pebble Time, Time Round, Time Steel, 2/2HR)
Choice of AI provider: Claude, Gemini, or ChatGPT
In-app settings UI for API keys, model, max tokens, and memory depth
Usage statistics per AI provider with reset option
Reminders, timers, and alarms set via AI and pinned to the Pebble timeline
Current weather conditions and 1-hour forecast (no API key required)
Token usage tracking per provider
Supports all Pebble platforms: basalt, chalk, diorite, emery, flint
Issues, suggestions, etc, email: alan@handsbreadth.com
Alan Johnson just released version 1.5 of hb MabelAI !
Host config page from external web server to support configuration on IOS.
After installing version 1.5 on my Pebble Time, it will not go into Setting. It does come up on my watch.
Update: Fixed in version 1.6
Alan Johnson just released version 1.6 of hb MabelAI !
Possible fix for the Settings page not displaying.
