jLynx
January 15, 2026, 11:55pm
1
Disc Golf Counter by jLynx
Leave your phone in the bag and focus on your throw! Disc Golf Counter is the ultimate wrist-based caddie for your Pebble, powered by real-time course data.
Unlike simple tally counters, this app uses your phone’s GPS to automatically find the nearest disc golf courses and download the actual scorecard layouts.
KEY FEATURES:
GPS Course Finder: Automatically detects nearby courses using UDisc data.
Smart Layouts: Select the specific layout you are playing (e.g., “Main”, “Advanced”, “Shorts”). Supports dynamic hole counts (9, 18, 27, etc.).
Live Scorecard: Tracks your strokes, current hole Par, and your total score relative to Par (e.g., +2, -1, E).
Persistent Storage: Your game is saved automatically. If you exit the app, your score is waiting for you when you return.
Readable Interface: Large, high-contrast numbers for easy reading in bright sunlight.
CONTROLS:
SELECT (Click): Add Stroke
SELECT (Long Press): Subtract Stroke (Undo)
UP (Click): Next Hole
DOWN (Click): Previous Hole
UP (Long Press): Refresh GPS / Find Course
DOWN (Long Press): Reset Round (Clear Score)
COMPATIBILITY: Works on all Pebble models (Original, Steel, Time, Time Steel, Round, 2).
Note: This app requires a connection to your phone to fetch course data.
jLynx just released version 1.1 of Disc Golf Counter !
Updated API
jLynx just released version 1.2 of Disc Golf Counter !
Updated API
