Decompress Dive Log by Konrad Iturbe
A simple dive log on your watch.
Syncs with PADI Logbook, requires an account with PADI previous to any use.
Use voice dictation and intuitive menus to record easy to forget data just as you hop on the boat or arrive at the dive center, instead of fiddling with your phone! I’ve found over the years of diving I kept forgetting key details (dive site, bottle size, nitrogen mix, etc…) after coming out of the water and was not recording this data anywhere. Dictate what you saw, how the dive went and anything you might want to remember later in the notes for the dive.
App shows the last 5 dives in your account, this is also useful as I never remember which weights were good for different oceans/seas, and which combination of bottle/weight was best. Click on a dive to see the details.
Last menu item to add a new dive, will prompt for key details:
Dive Title
Dive Site
Type of Dive
Max Depth
Bottom time
Notes: dictate using microphone
Water Type
Weather
Air Temp/Surface temp/Bottom temp
Visibility
Weights used
Start/end pressure
Then you can check all details later (and edit them) on the PADI Logbook app on your phone or on the PADI website.
Gabbro screenshots:
Konrad Iturbe just released version 1.1 of Decompress Dive Log !
code cleanup
show suggested dive sites from Padi API when dictating a new dive
Konrad Iturbe just released version 1.2 of Decompress Dive Log !
Fixed notes section, now displays up to 500 chars
