Watchapp: Bobby by Rebble
Bobby by Rebble
For anyone who may be unaware, bobby DOES work on the new Pebble app by Core Devices (coreapp), despite what the description says. You do need a Rebble subscription to use it still.
This only applies to Android though, correct? I went back to using the OG Pebble app in part to have access to Bobby, but my understanding via Discord is that it still isn’t functional on iOS. Am I wrong on this?
I have a Core2Duo and IOS and the new app. I can get past the “allow” question by using the settings page on the phone, and Bobby understands and captures my voice, but never asks for or gets a response, so no, it’s not quite working yet on IOS
I appreciate the response. I was bouncing between the Core app and OG app for awhile, but I got tired of reorganizing my watchfaces and decided to stick with the OG for now, but I’d really like to get back to the Core app, as I had much better stability with Bluetooth, and I get more battery (on the watch side AND the phone side) with it as well, but I don’t want to sacrifice the functionality, either.
First-world problems, I suppose. :rofl:
I bought a subscription. But it still doesn’t work.
Hey! Few questions for you:
  • Are you on iOS or Android?
  • Are you using the new orange Pebble Core app, or the legacy grey Pebble app?
  • What watch do you have?
iOS, new orange app, pebble 2 duo
Bobby doesn’t work on Core app on iOS yet unfortunately, only on Android
Ah, yep. Websockets aren’t working in the Core app for iOS yet - there are a handful of other watchapps having trouble with the same. Bobby won’t work on iOS until those are fixed.
If you’d like a refund for your subscription before then, feel free to reach out to support@rebble.io over email
