Block Crush brings the addictive block puzzle to your wrist. Drag colorful pieces onto an 8x8 board and fill rows or columns to crush them. You get three pieces at a time. Place them all and three more arrive. The game ends when none of your pieces fit, so think a move or two ahead.
Chain your clears to score big. Clearing several lines at once multiplies your points, and clearing again within three moves builds a combo for even more. Watch for bonus blocks: gems are worth extra points, x2 blocks double your next three clears, and bombs blast a 3x3 area when their line is crushed, setting off any other bombs they hit. Clear the whole board for a big bonus.
Every hand is fair. Whenever three new pieces are dealt, the game checks that they can all be placed in some order. Running out of space only ever comes from your own moves, never from an impossible hand.
On the Pebble Time 2 and Pebble Round 2, play by touch: drag a piece from the tray and it floats above your finger so you can always see where it will land, with the lines it will complete lit up. Every Pebble can also play with the buttons: pick a piece, step through the spots where it fits, and drop it. Line clears, combos and new high scores come with sound effects on watches with a speaker, and with vibration everywhere.
Beat your high score and a NEW HIGH SCORE celebration pops up on the spot. Your best score and your game in progress are saved automatically, so you can leave anytime and pick up where you left off. In the settings you can set the sound volume and keep the backlight on while you play, in a color of your choice on the Pebble Time 2.
Block Crush runs on every Pebble: Pebble Time 2, Pebble Round 2, Pebble 2 Duo, Pebble 2, Pebble Time, Pebble Time Round and Pebble Classic. Each has a layout made for its screen, whether color, black and white, or round.
