BatteryAlert by Sinaware
Sinaware just released version 1.1.0 of BatteryAlert!
Now the app works
Background worker was not set up correctly, so notifications never arrived.
Sinaware just released version 1.3.0 of BatteryAlert!
Alarm auto-stops after a duration you pick: 5 s (default), 10 s, 15 s, 30 s, or 1 min.
Choose when alarms fire: When charging (default), When draining, or Both.
Limiting to charging stops the watch buzzing/waking the app on every level as the battery drains — the app’s main battery cost.
Sinaware just released version 1.5.0 of BatteryAlert!
Richer alert sounds and clearer settings.
Tunes and beeps now play as a fuller two-voice (octave) sound through the Pebble Time 2 speaker, using the polyphonic speaker_play_tracks() API.
The Alert pattern picker now marks musical presets with a ♪ so it’s obvious which ones play a tune (♪ Mario, ♪ Ode to Joy, ♪ Twinkle Twinkle, ♪ Für Elise, ♪ Reveille) versus the plain buzz/beep patterns.
Added a short explanation in the settings page: ♪ tunes play through the Pebble Time 2 speaker, while watches without a speaker feel the pattern as vibration.
Sinaware just released version 1.5.1 of BatteryAlert!
BatteryAlert now has its own launcher icon instead of the default null icon
Sinaware just released version 1.6.0 of BatteryAlert!
• Alert levels are now set per direction — Charging, Draining, or both.
An 80% charge alert no longer buzzes when the battery drains past it.
• New Quiet hours: silence alerts overnight (window can cross midnight).
• The alarm now says “Charged 80%” or “Battery 20%” so you know why.
• Fixed the charging bolt showing as an empty box.
Existing settings carry over.
