Very very beginner
I have never coded before. how do I get into coding a watch face? any good direction to head? im sure there’s some intro tutorial stuff but thought I’d get one of yalls direction before I started into the void. cheers!
For a broad overview on programming in general, see CS50: Harvard’s computer science courses and certificates | edX
For a broad overview of the C language as a whole through the lens of Pebble, see Preface · Learning C with Pebble
For Pebble-specific tutorials, see https://developer.repebble.com/ they have both JS and C tutorials, the JS tutorials only work on the new Core Devices Pebble watches. There’s also Tutorials // Pebble Developers if you want to do development locally, instead of through the online code editor. Those JS tutorials only work with an older version of the SDK, on the original Pebble watches. Repebble.com is the new Core Dices website, rebble.io is the Rebble Foundation’s website. Generally the repebble site gets updated a little faster, though both sites should be pretty much equal when it comes to documentation. Tutorials will differ a little between the two sites though.
Also if you just want to get started by making simple faces, check out https://studio.pebbleface.com/ for a no-code solution.
