Thin by Chris Lewis
Simple, customizable watchface with splashes of color. Shows battery level with hour markers. Hour markers go green when charging.
Runs on both Pebble/Pebble Steel and Pebble Time/Time Steel.
Use the config page to adjust which features you want from:
Show weekday/month
Show day of the month
Show dis/connected indicator (outer ring)
Show battery level
Show seconds hand
Chris Lewis just released version 1.12 of Thin !
Scale up layout for Emery
Chris Lewis just released version 1.13 of Thin !
Add color theme options to configuration
Chris Lewis just released version 1.14 of Thin !
Fix use of @rebble /clay import
Chris Lewis just released version 1.15 of Thin !
Use pebble-packet library for AppMessage comms
Chris Lewis just released version 1.16 of Thin !
Build for flint
Use latest pebble-scalable library version
Chris Lewis just released version 1.18 of Thin !
Scale up for gabbro with pebble-scalable
