Tessera ad Infinitum by Tybbs
Tessera ad Infinitum transforms your Pebble into a window to an ever-changing world of generative art. Every hour, a new slice of a procedurally generated canvas is fetched and displayed as your watchface background.
Inspired by the original Perlin watchface and the work of Laurens Lapre, the art is created using layered Perlin noise fields with evolving color palettes, producing vibrant, organic patterns that are unique each time. No two hours look the same.
Features:
Full-screen generative art background, unique every hour
Hourly refresh
Large, readable time display in stacked hour/minute format or unstacked format
Date display below the time - configurable in settings
Battery-friendly: updates on the minute, fetches only on the hour
Aims to support all colored Pebble platforms
The watchface connects to the Tessera ad Infinitum API to fetch art slices sized to your exact screen resolution. An active Bluetooth connection to your phone with internet access is required for hourly art updates, but the last fetched art is saved and displayed even when disconnected.
