Watchface: Pebble Mesh by David Peer
:party: David Peer just released version 1.45 of Pebble Mesh!
Added a detailed weather screen (double flickr).
:party: David Peer just released version 1.46 of Pebble Mesh!
Improvements for detailed weather screen.
:party: David Peer just released version 1.47 of Pebble Mesh!
The temperature graph is now centered correctly
Thanks for all your hard work on this wonderful watchface :+1:
:party: David Peer just released version 1.48 of Pebble Mesh!
feat: Store weather details as well in case there is no connection to the phone
:party: David Peer just released version 1.49 of Pebble Mesh!
  • Add option for single flick as well
  • For +1d, +2d always show day icons
  • Better animation
:party: David Peer just released version 1.50 of Pebble Mesh!
Fix: Switching the color in case of dynamic quite time and a calendar event works now correctly.
:party: David Peer just released version 1.51 of Pebble Mesh!
Improved smoothness of forecast animation
:party: David Peer just released version 1.52 of Pebble Mesh!
Minor design changes
:party: David Peer just released version 1.53 of Pebble Mesh!
  • Each theme is individually customizable
  • Set your own date format (or a fixed text)
  • Disable the grid (for better contrast and readability)
Was already great, now even better!
:party: David Peer just released version 1.54 of Pebble Mesh!
Optional settings to vibrate on connect / disconnect
:party: David Peer just released version 1.55 of Pebble Mesh!
  • Included heart rate
  • More options for forecast duration
A suggestion: how hard would it be to add an option to display the time with seconds after flicking the wrist? Often, I’d like to know how close we are to the next minute, but I don’t want to display seconds all the time because of battery usage: seems like showing seconds after double-flicking the wrist would be a good way to do it.
Also, can you please add Humidity?
:party: David Peer just released version 1.56 of Pebble Mesh!
  • PebbleTime2: Bigger time font
  • Support custom colors for both, dark and light theme
  • Pebble Steel: Removed support to keep it maintainable (sry)
