HRTminder by MayaTel Labs
HRTminder is a customizable watchface that is designed to be the answer to the most common pitfall of being a transgender person - the question of “ah, shoot, when was the last time I took my meds/injection/etc”?
Customizable medication regimen!
I mean, everyone takes their HRT differently, after all. The interval at which you take your meds, what time of day you take them, and what method through which you take them (injections, pills, something else, a generic option, or something custom entirely).
Customizable medication nagging settings!
Listen, I sometimes don’t do things I need to without someone telling me to do it. That’s just how it goes. HRTminder allows you to enable a setting that requires you to actively press a button to affirm you’ve taken your meds - and, if you haven’t, tells you that your meds are overdue and how overdue they are.
The watchface yells at you!
Are YOU autistic? Do YOU not cope well with object personification? Then do I have the feature for you, because with the “guilt” setting turned on, HRTminder will display a random selection from a number of preprogrammed messages shaming you into taking your meds in one way or another, including by telling you that your watch is sad! New messages are always being added as I can think of them, too, so it’s always a surprise!
Customizable typefaces!
We have four open-source clones of popular typefaces in here - U001, Inter, Jost*, and DINish. We think they look good. (Medication widget does not support Inter and Jost* due to width constraints).
Customizable lower information display!
Choose between just having the battery percentage or having the battery percentage paired with a number of options, including a second timezone, the daily high and low temperature, the upcoming sunrise/sunset time, the phase of the moon, or Swatch Internet Time!
Weather displays!
The primary watch display always shows the current temperature and current conditions, based on your phone’s GPS location. The bottom display can also be configured to show the high/low temperatures or the sunrise/sunset times. (Requires free OpenWeatherMap API key).
MayaTel Labs just released version 1.1 of HRTminder !
Updated to provide compatibility with Pebble Time 2.
MayaTel Labs just released version 1.2 of HRTminder !
Resolved major issue with how widget fonts were rendering on Aplite devices introduced in the 1.1 release (whoops), stemming from incorrect ordering of font handling.
MayaTel Labs just released version 1.3 of HRTminder !
Significant improvement in battery consumption (theoretically) - the whole watchface only redraws once per minute now instead of on every second
