Halcyon by Freakified
Freakified just released version 1.7 of Halcyon!
v1.7: “At last, the stage is set”
- [new feature] All-new modern design for settings page supporting both light and dark mode
- [new feature] Night theme: use a different theme after sunset, thus completing the circle of life
- [new feature] Save, load, or share your custom themes!
- [new feature] Setting to show or hide the leading zero from the time (thanks KonradIT!)
- [improvement]: 15 new color themes, including both light and dark styles
Freakified just released version 2.0.0 of Halcyon!
Version 2.0:
- [New feature] Up to 4 user-selectable widgets, including weather, heartrate, steps, local date formats, and more!
- [New feature] Custom widgets! Add a monogram or even create your own hybrid widgets featuring any available data!
- [New feature] Experimental localization! Widgets are fully localized to 37 different languages, including weather conditions and date formats! (Note: translations are currently experimental; if you find an error in your language, please contact me!)
- [New feature] Support for Pebble Round 2
- [Improvement] Graphics are now scaled more accurately for the Pebble Time 2 screen size
Freakified just released version 2.1.0 of Halcyon!
v2.1
- Fix wrong config page URL
Freakified just released version 2.1.1 of Halcyon!
v2.1.1
- Improvements to Russian translation (thanks saraysxroom!)
- Chance of rain widget now uses mean instead of max probability
Freakified just released version 2.1.2 of Halcyon!
v2.1.1
- Fix for bug where weather had stopped updating
Freakified just released version 2.1.3 of Halcyon!
v 2.1.3:
- Fix: Sunrise/sunset widget no longer flashes 12 hour format if watch is set to 24 hour format
- Config page fix: Custom widget builder uses slightly more sensible names for sunrise/sunset tokens
- Config page fix: Dial markings setting now shows the correct number of hours for “only major”
Freakified just released version 2.2 of Halcyon!
- v. 2.2
- New widgets: World Time!
- Display the time in 2 of your favorite cities!
- Automatically factors in daylight savings time
- New feature: Option to use uniform font size for all widgets
- Not a fan of the smaller font on the uppermost and lowermost widgets? Now you can make them all use the same size!
- Improvement: Long widget text is now clipped instead of using an ellipsis, so you can get slightly more characters in there on small watches
I applaud your effort to make the watchface very configurable. However, fewer items simultaneously in the display that are readable would be more practical.
The real time preview without having to Save inspires me to implement the same in my own watchfaces. Kudos to you.
Glad the real time preview is helpful for you! To do it, I built a reusable React framework for hosted config pages – feel free to grab it from Github if you’d like to give it a try for your watchfaces!
Without enabling Uniform Font Size and Larger Font Sizes, the top and bottom lines are nearly impossible to read on Pebble Time Steel without reading glasses, and looking carefully. That’s with the watch resting on a desk. On my wrist would be entirely impossible.
I added the larger options to ensure readability, but they come at the tradeoff of less space for content, unfortunately!
The grayed out top and bottom text is difficult enough to read without being grayed out. Consider not graying that text out.
Feel free to adjust the color! The theme builder is designed to let you change any color on the watchface, including the secondary widget text color!
When enabling Temperature, Imperial, Uniform Font Size, and Large Font Sizes, the temperature displayed is wider than the area for it to be displayed.
On the Time 2 and Round 2, it does fit with all those options enabled! You’re right that it ends up too wide for the Time Steel though – perhaps I can adjust the defaults to remove the parenthesis, which would fit:
In the meantime, you can paste this into the custom widget builder to get one without parens, that fits:
{temp}° {thi}°/{tlo}°
Freakified just released version 2.3 of Halcyon!
V 2.3
- [Fix] No longer tries to fetch weather data if all weather widgets are disabled
- [Fix] Weather widgets longer flash “–" while weather is reloading
- [Improvement] Weather now retries if a refresh operation fails, instead of immediately giving up
- [Fix] On the settings page, the reset settings button now works on iOS
- [Improvement] On the settings page, custom themes now are shared between night and day sections
- [Improvement] New set of default themes, verified on real watches for readability
