Ferrofluid by John LaRocque
A fluid simulation in the palm of your hand! Or, on the back of your wrist…
This watchface uses a modified double density relaxation sim and “magnets” to form fluid particles into the current time. Configurable color, “font,” sim duration (per digit change), and backlight-triggered simulation.
Warning! Although it’s highly optimized, this will push your Pebble to its limits - with the default settings expect about half of normal battery life (~15 days on Pebble 2 Duo).
Thank you to Clavet, Beaudoin, and Poulin at the Université de Montréal, upon whose paper the sim is based.
Gabbro screenshots:
John LaRocque just released version 0.2.0 of Ferrofluid !
add aplite (OG and OG Steel) support. Note: battery life is particularly poor on aplite; I wouldn’t recommend this as a daily driver
