Watchface: Facets by Lixic
Facets by Lixic
:party: There’s a new watchface on the Rebble App Store!
:party: Lixic just released version 0.8.5 of Facets!
New:
-Weather conditions added
Changed:
-Changed weather refresh behaviour so that it will also refresh on returning to the watchface. Default 30-minute interval remains unchanged
-Slight alignment adjustment of weather widget and step counter
:party: Lixic just released version 0.8.6 of Facets!
New:
-12h time now supported
:party: Lixic just released version 0.9.0 of Facets!
New:
-Heart rate status using HealthService API
-New weather condition for “Clear”
Changes:
-Moved quiet time indicator to separator bar
-Tweaked status padding
-Removed some redundant code
:party: Lixic just released version 0.9.7 of Facets!
New:
-Initial implementation of watchface settings
-Ability to switch to temperature units to Fahrenheit
-Accent colours
-Light mode
-Ability to disable watchface complications
Changed:
-Moved heartrate icon to the left of the value
-Optimised code for lower RAM usage
-Removed several redundancies
-Redesigned AM/PM indicator for consistency
-Tweaked initial weather value behaviour to reduce likelihood of handshake errors over poor bluetooth connections
:party: Lixic just released version 1.0.0 of Facets!
Version 1.0 is here!
New:
-Added stepcount goals to watchface settings (8k, 10k and custom)
-Added an alarm indicator icon when a watch alarm is enabled
Changed:
-Changed the font of complications to JetBrains Mono
-Fixed inconsistent font rendering by double-rendering smaller text and offsetting by 1px
-Changed alignment and sizing of the heartrate complication
-Switched the dotted separator line to a solid line for a cleaner visual appearance
-Many small alignment tweaks
-Slightly tweaked weather fetching behaviour
-Slightly changed settings categories
-Moved the AM/PM indicator for 12h time to above the clock for easier visibility
:party: Lixic just released version 1.0.1 of Facets!
New:
-Added the option for manual weather location in settings
Changes:
-Fixed a bug where disabling weather would still fetch weather data in the background
-Tweaked padding for lower watch complications
:party: Lixic just released version 1.0.4 of Facets!
New:
-Added a toggle in settings for hourly vibration
-Added the ability to change the refresh interval of weather; 30 mins (default) and custom
Changes:
-Changed font for battery indicator to JetBrains mono thin for better readability and consistency
-Changed the behaviour of disabling step counter & heartrate monitor so the watchface will no longer remain subscribed to Pebble’s health event service. This should improve battery life when step counter and heartrate are disabled
-Changed the style of toggle switches in settings for consistency
:party: Lixic just released version 1.0.7 of Facets!
New:
-Added a new “Angular” font option to settings
Changes:
-Improved the loading time and reliability of the weather complication on initial loading
-Changed the font of the date complication to JetBrains mono for consistency with other complications
:party: Lixic just released version 1.0.8 of Facets!
Changes:
-Slight tweak to syncing handshake logic
:party: Lixic just released version 1.0.9 of Facets!
Changes:
-Fixed a bug causing significant battery drain under certain conditions
:party: Lixic just released version 1.1.1 of Facets!
Changes:
-Changed behaviour of the status bar so that it will now occupy the space below when both stepcounter and weather are disabled
-Fixed clock alignment when timeline peek is showing to prevent overlapping elements
-Slight tweaks to the design of the watchface settings page
:party: Lixic just released version 1.1.2 of Facets!
Changes:
-Fixed a bug with persistent storage for weather values
