Watchface: DATALOAD by heje
DATALOAD by heje
:party: There’s a new watchface on the Rebble App Store!
:party: heje just released version 2.1.2 of DATALOAD!
  • Minor UI tweaks
:party: heje just released version 2.1.5 of DATALOAD!
  • Added week number and moon-phase as an option in the left side detail slot.
  • Next weather event time now indicates am/pm after the time in 12 hr mode
:party: heje just released version 2.2.0 of DATALOAD!
  • Rain chart weather icon thresholds have been adjusted and now should match rain chance better
  • Left and right clock slots can be set to None (empty)
  • Humidity added as a right-column metric option so that entire row can be weather-themed (it’s still in the left-side detail)
  • New toggle to hide the UV index bar in settings
  • Next weather event times that are on the hour use a more compact format to avoid potential overlapping issues in 12hr mode (5:00p on the hour will show as 5p)
:party: heje just released version 2.3.0 of DATALOAD!
  • All data points in the left and right side detail slots can be shown on either side (aside from the defaults for each side)
  • Changed the label on the heat index item to convey that it switches to wind chill calculation during colder weather temps (instead of just changing the name)
  • Minor UI tweaks to balance layout with the new entries to each side detail slot
  • Minor bugfixes
:party: heje just released version 2.4.0 of DATALOAD!
  • Added themes! There’s just a few ones to start, but more will be coming very soon.
  • Added alternate timezone to left side detail slot. Just select the UTC offset in the settings.
:party: heje just released version 2.5.0 of DATALOAD!
  • Both top data cluster rows are now fully customizable (each cluster can display any currently-available readout)
  • Rain chart bars now more accurately display very low precipitation chances relative to other segments
  • Added option to hide rain chart bars on segments when precipitation chance is very low
  • Added 2 new themes
  • Reworked Amber theme and renamed it to Amber Console
  • Reworked Midnight theme and renamed to Blueprint
  • Minor UI tweaks and bugfixes
:party: heje just released version 2.5.1 of DATALOAD!
  • Added phone battery side detail item (dependent on your device’s WebView capability; the settings page will display whether your device can display it or not)
  • Tweaked rain chart bar margins so spacing is consistent between segments
  • Tweaked some of the themes
:party: heje just released version 2.6.0 of DATALOAD!
  • Data clusters in both of the top rows are fully interchangeable can be displayed in any position
  • Heart rate sensor update intervals can now be customized, except in situations where the Pebble SDK overrides the requested interval (e.g. low battery, workout, etc.)
  • Added new steps goal cluster
  • Added a few more themes
:party: heje just released version 2.6.1 of DATALOAD!
  • Hotfixes for some top row configurations
:party: heje just released version 2.6.2 of DATALOAD!
  • More hotfixes for the 2.6.0 update
  • Added compass data cluster (with adjustable redraw throttle)
:party: heje just released version 2.6.3 of DATALOAD!
  • Fixes for the new compass cluster
:party: heje just released version 2.7.0 of DATALOAD!
  • Added new top row data clusters:
    • PM2.5
    • Active minutes
    • Calories goal
  • Added new side-detail data readouts:
    • UV peak today
    • Wind gust
    • Cloud cover
    • Actual precipitation (in/mm)
  • Moved customizable rows section above clock in settings
:party: heje just released version 2.7.1 of DATALOAD!
  • Added option to display last weather update time in the same slot as the weather location above the current hi/lo temperatures
  • Minor tweaks and bugfixes
:party: heje just released version 2.8.0 of DATALOAD!
  • Many bugfixes and backend improvements:
    • Rain chart icons and bars now more accurately sync to the interval displayed even if weather hasn’t been updated in awhile
    • Manual weather location handling has been improved and will invalidate/clear bad user input instead of mismatching/hanging
    • Weather fetching will now timeout instead of retrying continuously on flaky networks (to conserve battery)
    • UV Index is now more accurate when traveling as it also considers the forecast location’s timezone
    • Reduced the memory footprint by unloading and consolidating fonts when possible
    • Reduced the amount of redundant fetches by consolidating and repackaging the data from your current cluster configuration
    • Further improvements to screen redraw efficiency by reducing unnecessary work on each tick (especially when theme has been changed, seconds are turned off, etc.)
    • Other minor tweaks and improvements not worth mentioning on their own
:party: heje just released version 2.9.0 of DATALOAD!
  • Added more choices to the customizable top cluster rows
  • Added matching backlight color to themes
  • Removed Dark room theme and turned it into a mode where it changes the theme and backlight color automatically during sleep hours
  • Fixed weather update bug introduced in last update (the interval set now resides in the watch)
  • Minor UI tweaks
:party: heje just released version 2.9.1 of DATALOAD!
  • Further improvements to the weather update logic
  • Minor bugfixes
:party: heje just released version 3.0.0 of DATALOAD!
  • Added 4 new themes
  • Added option to use system backlight color on all themes
  • Tweaked light theme to improve contrast
  • Reduced overall file size
:party: heje just released version 3.1.0 of DATALOAD!
  • Added custom profiles (up to 10) to quickly swap between different configurations depending on activity or use-case
  • Sections in settings are now collapsible to make it easier and quicker to find what you’re looking for
  • Added sun path cluster as an option in the top cluster rows that also shows remaining daylight hours
  • Bugfixes and UI tweaks
:party: heje just released version 3.1.1 of DATALOAD!
  • Minor bugfixes
