Brad Monk just released version 3.5.2 of Big Time!
Big Time is now free, with all customization unlocked and optional tips. Added independent Bluetooth disconnect vibration and an optional timestamped popup. Improved Settings opening and step-goal notifications. Support: Support Big Time
Brad Monk just released version 3.5.3 of Big Time!
Digital clock expansion is now enabled by default, so hiding the top, bottom, or progress bar lets the clock fill the available space. Restore Defaults also enables expansion; existing saved preferences are respected. All features remain free.
Optional support: Support Big Time
Brad Monk just released version 3.5.5 of Big Time!
• Bluetooth disconnect vibration is now disabled by default. Existing saved preferences are respected.
• Settings now shows a copyable donation-page address with a Copy address button and manual-copy fallback.
• Added spacing above the Copy button.
All features remain free. Optional support: Support Big Time
Brad Monk just released version 3.5.6 of Big Time!
Added Danish (Dansk) for both the watchface and Settings, including dates, data labels, settings help, profile dialogs, and notification text. Select Dansk under Watchface & Settings Language, then Save Settings.
Brad Monk just released version 3.5.7 of Big Time!
Fixed Custom URL in the Data Dashboard. Selecting Custom URL now shows the URL address, optional label, and refresh interval for that slot. Each dashboard slot has its own custom data source. Controls follow dashboard visibility and the 2×2 or 2×3 layout, and saved values are retained when switching options.
Brad Monk just released version 3.5.14 of Big Time!
• Added Blank for each of the six top and bottom bar slots.
• Added Japanese for the watchface and Settings.
• Improved text fitting throughout the information bars and 4-item and 6-item dashboards.
• Corrected battery icon/percentage alignment. Dashboard labels stay at the top, with data centered in the remaining space.
• Improved Settings saving for larger configurations.
Brad Monk just released version 3.5.15 of Big Time!
Improved Data Dashboard alignment in both 4-item and 6-item layouts. Labels remain at the top; values and icons are centered in the space directly below the label, with a one-pixel upward adjustment for visual balance.
Brad Monk just released version 3.5.18 of Big Time!
Improved vertical alignment in the top and bottom information bars when labels are hidden. Large top-bar text, including weekdays and months, is raised slightly for better visual centering.
