Watchapp: Timer Core by Antoine
:core-2-duo-black: Flint screenshots:
:party: Antoine just released version 1.1 of Timer Core!
Add Gabbro
Change layout
What a pity. It seems you have dropped support for the OG pebble Steel :disappointed_face:
Your app was the one that I used most on my watch, several times a day. Is there any chance to get it back??
Hi, thanks for your feedback. I’m pleased to read that the app is used.
This app is a reborn of the “Series timer” watchapp I’ve made 10y ago. I was not able to recover my old dev account, so I decide to create a new version for new devices. I just drop OG pebble and time round, because it take too much time to support those platforms +the new ones. Also OG pebble have a big memory issue (24kB max if I remerber well) wich it add more challenge to handle.
Whatever the former version still work on OG and round with a storage of 12 configuration (raised to 20 in new version).
You can find “Series timer” at Series Timer
There is an other version called “Series timer A” that allow you to have a bunch of 12 more selections. You can also start the 2 versions at the same time to start 2 timers instance at the same time.
On the former version you still have the ability to change font and bezel. Those features have been drop in the new version.
Enjoy
Hi Antoine, thank you for your message!
I perfectly understand that supporting the old watches makes it more difficult for you. Actually I use your app only as a timer, when preparing myself a tea. There are simpler apps that can do the same, but I really like the visual countdown display of your app, and with the option to change the font it is even better.
Thank you so much for informing me about the old app. This is the perfect solution for me.
I wish you a good continuation and progress with your app, and kind regards, Johannes
:party: Antoine just released version 1.2 of Timer Core!
aplite back : 8 timers with 4 segments
There is a new release supporting OG.
:party: Antoine just released version 1.3.0 of Timer Core!
add touch and sound
