Oliver Bender just released version 6.13.0 of **GymTracker **!
Configurable Note Toast Visibility!
You can now customize how long Note Toasts stay on your screen. Choose from 6 new options:
-Auto-dismiss: 8, 15, or 20 seconds.
-Permanent: During Workouts, Rest periods, or Both.
A massive shoutout to silentjay for developing and improving this feature!
Oliver Bender just released version 6.13.1 of **GymTracker **!
Added Manual mode to the Note Toast options.
Oliver Bender just released version 6.14.0 of **GymTracker **!
New Feature: Customizable Set Pre-filling
You can now fully customize how your active workout screen is pre-filled when starting a new set! Head over to the Settings menu to choose between three distinct modes:
Targets (Default): Pre-fills with your set goals, maintaining the classic app behavior you are used to.
History: Intelligently pulls your actual completed reps and weight from the last time you ran this specific routine.
Zero: Starts every set with a blank slate (0) for complete manual entry.
A huge shoutout to @vortexmak for suggesting this feature!
Oliver Bender just released version 6.14.1 of **GymTracker **!
Solves a bug where routine history on watch would be deleted whenever an update is sent from the companion website.
Oliver Bender just released version 6.15.0 of **GymTracker **!
Custom Rest Timers: You can now set exact, custom rest times! Need a 4-minute rest for heavy compound lifts? Simply long-press any of the rest timer options (Set Rest, Exercise Rest, Super Rest, or Drop Rest) in the Settings menu.
New Time Picker Window: The long-press action now opens a dedicated Time Picker. Use the Up/Down buttons to precisely dial in your perfect rest period (hold them down to scroll rapidly!) and lock it in with the Select button.
Oliver Bender just released version 6.15.1 of **GymTracker **!
Fix: Resolved an issue where saving long routines or auto-progression changes would silently fail to sync to the watch due to Pebble app transfer limits.
Improvement: Optimized configuration sync payload size and added warnings if routine data exceeds transfer limits.
Oliver Bender just released version 6.16.0 of **GymTracker **!
Add Sets On the Fly:
Still have some gas in the tank? You can now instantly append an extra set to your current exercise mid-workout directly from the watch using the double-click action menu or binding it to a shortcut!
Bug Fixes:
-Squashed a bug that caused the “Saved on Phone” routine list to appear empty on fresh app installs.
-Fixed a watch memory issue when pushing past 10 sets in a single exercise.
-Cleaned up “Ghost Pacer” data leaks so deleted routines don’t haunt your new workouts.
Thx to Dreamkeeper for the PR!
Oliver Bender just released version 6.16.1 of **GymTracker **!
Critical Crash Fixes: Resolved an issue where selecting a routine could crash the app on some platforms.
Memory Optimization: Optimized Bluetooth message buffers to free up over RAM, drastically improving app stability on legacy hardware.
Ghost Pacer & Set Adjustments: Patched slot-swapping memory logic and added strict bounds-checking to the new mid-workout set expansion feature.
Oliver Bender just released version 6.18.0 of **GymTracker **!
Avg and peak HR is now tracked per set of each exercise.
New jump to exercise window implemented.
